ap-location
Configures an AP‘s deployment location based filter for this user-defined role
Syntax
ap-location [any|contains|exact|not-contains]
ap-location any
ap-location [contains|exact|not-contains] <WORD>
Parameters
ap-location any
ap-location any
Specifies the AP location to match (in an RF Domain) or the AP‘s resident configuration
  • any – Defines an AP‘s location as any
ap-location
Specifies the AP location to match (in an RF Domain) or the AP‘s resident configuration. Select one of the following filter options: contains, exact, or not-contains.
contains <WORD>
Applies role if the associating AP‘s location contains the location string specified in the role.
  • <WORD> – Specify the location string to match.
exact <WORD>
Applies role if the associating AP‘s location exactly matches the string specified in the role.
  • <WORD> – Specify the exact location string to match.
not-contains <WORD>
Applies role if the associating AP‘s location does not contain the location string specified in the role.
  • <WORD> – Specify the location string. The role is applied if the location does not match the specified string.
nx9500-6C8809nx9500-6C8809(config-role-policy-test-user-role-testing)#ap-location contains office
nx9500-6C8809(config-role-policy-test-user-role-testing)#show context
 user-role testing precedence 10
Related Commands
no
Removes an AP‘s deployment location string from this user-defined role
